Error in Orion Platform: Network Atlas has encountered a problem and needs to close
This general error message may be caused by one or more of the following: Diagnostics Examine the log file at C:\Documents and Settings\All Users\Application\Data\SolarWinds\NetworkAtlas\NetworkAtlas.log. Go to the bottom of the file, then scroll up. Ignore the lines that start with "at". Above the "at" lines, if you see the error, "class not registered", it means that one of the DLLs in Network Atlas is not registered correctly. Sometimes, this happens with the Tom Sawyer drawing libraries.
Diagnostics
- Examine the log file at C:\Documents and Settings\All Users\Application\Data\SolarWinds\NetworkAtlas\NetworkAtlas.log. Or C:\ProgramData\SolarWinds\NetworkAtlas\NetworkAtlas.log.
- Go to the bottom of the file, then scroll up.
- Ignore the lines that start with "at".
- Above the "at" lines, if you see the error, "class not registered", it means that one of the DLLs in Network Atlas is not registered correctly. Sometimes, this happens with the Tom Sawyer drawing libraries.
May also see the following error from the NetworkAtlas.Log
2021-10-21 11:20:33,939 [Main Window UI thread] FATAL NetworkAtlas - UNHANDLED EXCEPTION CAUGHT ON UI THREAD.
2021-10-21 11:20:33,954 [Main Window UI thread] FATAL NetworkAtlas - Message: An item with the same key has already been added.
2021-10-21 11:20:33,954 [Main Window UI thread] FATAL NetworkAtlas - Data: System.Collections.ListDictionaryInternal
2021-10-21 11:20:33,954 [Main Window UI thread] FATAL NetworkAtlas - TargetSite: Void ThrowArgumentException(System.ExceptionResource)
2021-10-21 11:20:33,970 [Main Window UI thread] FATAL NetworkAtlas - StackTrace: at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
ERROR 2:
2022-04-14 12:58:21,897 [1] FATAL NetworkAtlas - Source: System.Xml
2022-04-14 12:58:21,897 [1] FATAL NetworkAtlas - HResult: -2146232000
2022-04-14 12:58:46,600 [1] WARN NetworkAtlas - Starting Network Atlas version 1.23.0.50014
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - UNHANDLED EXCEPTION CAUGHT ON APPLICATION DOMAIN
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - Message: Configuration system failed to initialize
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - BareMessage: Configuration system failed to initialize
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - Line: 0
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - Errors: System.Configuration.ConfigurationException[]
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - Data: System.Collections.ListDictionaryInternal
2022-04-14 12:58:46,709 [1] FATAL NetworkAtlas - InnerException: System.Configuration.ConfigurationErrorsException: '.', hexadecimal value 0x00, is an invalid character. Line 6, position 1. (C:\Users\x<username>\AppData\Local\SolarWinds_Worldwide,_LLC\NetworkAtlas.exe_Url_cs5ltsenrn4ss3wmmf3hdqyynirlyeqy\1.23.0.50014\user.config line 6) ---> System.Xml.XmlException: '.', hexadecimal value 0x00, is an invalid character. Line 6, position 1.
- A custom property contains An invalid character such as #.
- A DLL required by Network Atlas may not be correctly registered.
- The user.config file has invalid characters
Resolution 1:
Rename any custom properties that contain invalid characters such as # in the name. Limit your custom property names to letters and numbers.
Resolution 2:
1. Check the MapStudioFiles table for duplicates. If it has duplicate entries, proceed to the next step. You may use the SQL Query below to check for duplicates:
# 'Disclaimer # 'The sample scripts are not supported under any SolarWinds support program or service. # 'The sample scripts are provided AS IS without warranty of any kind. # 'SolarWinds further disclaims all implied warranties including, without limitation, any implied warranties of merchantability or of fitness for a particular purpose. # 'The entire risk arising out of the use or performance of the sample scripts and documentation stays with you. # 'In no event shall SolarWinds or anyone else involved in the creation, production, or delivery of the scripts be liable for any damages whatsoever # '(including, without limitation, damages for loss of business profits, business interruption, loss of business information, or other pecuniary loss) # 'arising out of the use of or inability to use the sample scripts or documentation. SELECT FileName, COUNT(*) FROM MapStudioFiles GROUP BY FileName HAVING COUNT(*) >1
2. Backup the database or the MapStudioFiles table
3. Run the following query:
# 'Disclaimer # 'The sample scripts are not supported under any SolarWinds support program or service. # 'The sample scripts are provided AS IS without warranty of any kind. # 'SolarWinds further disclaims all implied warranties including, without limitation, any implied warranties of merchantability or of fitness for a particular purpose. # 'The entire risk arising out of the use or performance of the sample scripts and documentation stays with you. # 'In no event shall SolarWinds or anyone else involved in the creation, production, or delivery of the scripts be liable for any damages whatsoever # '(including, without limitation, damages for loss of business profits, business interruption, loss of business information, or other pecuniary loss) # 'arising out of the use of or inability to use the sample scripts or documentation. DECLARE @file nvarchar(max) DECLARE cleanup_duplicated_pictures CURSOR FOR select [FileName] from MapStudioFiles group by [FileName] having count(FileId) > 1 OPEN cleanup_duplicated_pictures FETCH NEXT FROM cleanup_duplicated_pictures INTO @file WHILE @@FETCH_STATUS = 0 BEGIN delete from MapStudioFiles where FileId in ( select FileId from MapStudioFiles where [FileName] = @file ) and FileId not in ( select top 1 FileId from MapStudioFiles where [FileName] = @file ) FETCH NEXT FROM cleanup_duplicated_pictures INTO @file END CLOSE cleanup_duplicated_pictures DEALLOCATE cleanup_duplicated_pictures
4. Launch the Network Atlas.
Resolution 3:
The solution is to run a Repair of Network Atlas. If the repair does not work, you can try to uninstall and reinstall Network Atlas.
Resolution 4:
Disable and then enable SolarWinds services
Resolution 5:
- Verify the SWQL query used by NetworkAtlas that can be found in NetworkAtlas.log. See the example below:
SELECT Nodes.NodeID, Nodes.ObjectSubType, Nodes.IPAddress, Nodes.IPAddressType, Nodes.DynamicIP, Nodes.Caption, Nodes.NodeDescription, Nodes.Description, Nodes.DNS, Nodes.SysName, Nodes.Vendor, Nodes.SysObjectID, Nodes.Location, Nodes.Contact, Nodes.VendorIcon, Nodes.Icon, Nodes.Status, Nodes.PolledStatus, Nodes.StatusLED, Nodes.StatusDescription, Nodes.CustomStatus, Nodes.IOSImage, Nodes.IOSVersion, Nodes.GroupStatus, Nodes.StatusIcon, Nodes.LastBoot, Nodes.SystemUpTime, Nodes.ResponseTime, Nodes.PercentLoss, Nodes.AvgResponseTime, Nodes.MinResponseTime, Nodes.MaxResponseTime, Nodes.CPUCount, Nodes.CPULoad, Nodes.MemoryUsed, Nodes.LoadAverage1, Nodes.LoadAverage5, Nodes.LoadAverage15, Nodes.MemoryAvailable, Nodes.PercentMemoryUsed, Nodes.PercentMemoryAvailable, Nodes.LastSync, Nodes.LastSystemUpTimePollUtc, Nodes.MachineType, Nodes.IsServer, Nodes.Severity, Nodes.UiSeverity, Nodes.ChildStatus, Nodes.Allow64BitCounters, Nodes.AgentPort, Nodes.TotalMemory, Nodes.CMTS, Nodes.CustomPollerLastStatisticsPoll, Nodes.CustomPollerLastStatisticsPollSuccess, Nodes.SNMPVersion, Nodes.PollInterval, Nodes.EngineID, Nodes.RediscoveryInterval, Nodes.NextPoll, Nodes.NextRediscovery, Nodes.StatCollection, Nodes.External, Nodes.Community, Nodes.RWCommunity, Nodes.IP, Nodes.IP_Address, Nodes.IPAddressGUID, Nodes.NodeName, Nodes.BlockUntil, Nodes.BufferNoMemThisHour, Nodes.BufferNoMemToday, Nodes.BufferSmMissThisHour, Nodes.BufferSmMissToday, Nodes.BufferMdMissThisHour, Nodes.BufferMdMissToday, Nodes.BufferBgMissThisHour, Nodes.BufferBgMissToday, Nodes.BufferLgMissThisHour, Nodes.BufferLgMissToday, Nodes.BufferHgMissThisHour, Nodes.BufferHgMissToday, Nodes.OrionIdPrefix, Nodes.OrionIdColumn, Nodes.SkippedPollingCycles, Nodes.MinutesSinceLastSync, Nodes.EntityType, Nodes.DetailsUrl, Nodes.DisplayName, Nodes.Category, Nodes.IsOrionServer, Nodes.Image, Nodes.AncestorDisplayNames, Nodes.AncestorDetailsUrls, Nodes.StatusIconHint, Nodes.Uri, Nodes.InstanceSiteId, Nodes.CustomProperties.NodeID, Nodes.CustomProperties.Address, Nodes.CustomProperties.AlertOnThis, Nodes.CustomProperties.AssetTag, Nodes.CustomProperties.City, Nodes.CustomProperties.CosaMap, Nodes.CustomProperties.DeviceType, Nodes.CustomProperties.Latitude, Nodes.CustomProperties.Longitude, Nodes.CustomProperties.Region, Nodes.CustomProperties.SiteCode, Nodes.CustomProperties.Sites, Nodes.CustomProperties.State, Nodes.WebUri.WebUri FROM Orion.Nodes (nolock=true) ORDER BY Nodes.DisplayName RETURN XML AUTO
- Run the query and observe for a timed out error
- If timed out occurs, remove each column in the query then try to run until no timed out
- Once found the column that causing timed out, verify the values of the said column i.e (CustomProperties)
- Update or correct the value of the column that causing timed out
For ERROR 2,
- Back up the user.config file located according to the error and relaunch the Network Atlas
Resolution 7:
NOTE: After upgrading, Network Atlas has encountered a problem and needs to close. We are sorry for the inconvenience. Please contact SolarWinds support about this problem.
- Reboot the polling engine were the error was seen.
