Applications Systems
Adjust Logging for SolarWinds.SEUM.AgentDomainConfigurationTool.exe
WPM SolarWinds.SEUM.AgentDomainConfigurationTool.exe.config. SolarWinds WPM Domain Accounts Configuration Tool is failing. domain configuration tool displaying error. Mutex G. Wait for access to mutex has timed out Global/S. Player domain user tool is malfunctioning. Single sign-on users, agent active directory users, Player worker processes.
Useful in situations where the following message is received in the Domain Configuration tool.
See also:
• Wait for access to mutex has timed out Global/S
• Configuring domain accounts in WPM
\ProgramFiles (x86)\SolarWinds\Orion\SEUM\Player\
The configuration file that governs the tool is located in the same path with a .CONFIG file extension (e.g.SolarWinds.SEUM.AgentDomainConfigurationTool.exe.config). The entry to adjust is <level value="INFO" within the sections
<log4net> ... <root> <level value="INFO"/> </root> ... </log4net>
You may set to one of the following:
- OFF
- VERBOSE
- TRACE
- DEBUG
- INFO
- WARN
- ERROR
C:\ProgramData\SolarWinds\Logs\SEUM
