Additional polling engine is showing as down due to a DNS issue
This article discusses the resolution where the additional polling engine is showing as down due to a DNS issue.
- Fix the DNS issue.
Note: This needs to be discussed with your DNS administrator(s). - Alternatively, add a record to the local resolver (
hostsfile):- Open Notepad (or any other text editor) by right clicking and selecting Run As Administrator.
- Open following file:
c:\Windows\System32\drivers\etc\hosts - Add a record (line) similar to example below:
192.168.123.123 SomeHostName - Close (save) the file.
- Test from the command line using
pingif the resolution works.ping SomeHostName
andping -a 192.168.123.123
- Restart all Orion Services.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
