Applications Systems
Add Player locations
How to add a player server in WPM.
11/12/2018 11:56 AM
11/12/2018 11:56 AM
Web Performance Monitor
  1. Login to the Orion Web Console.
  2. Go to Settings > WPM Settings > click Manage Player Locations > click Add Location.
  3. Now you have these options to add the player:
    1. Install location on my network (A player will be deployed to the desired network location).
    2. Add a location in the cloud (Select this option if you do not have access to the physical hardware at your desired location. A cloud location will be created).
    3. Add an existing location (A player must already be installed on the local machine or at a remote location to play the recording.)
  4. Complete the steps accordingly.
Note: Make sure the player can connect to the WPM poller or you can telnet on port 17781 from the WPM poller to the player.
