Applications Systems
Active Directory component monitor intermittently goes Unknown
The component monitoring services intermittently goes to Unknown state.
10/15/2018 4:16 PM
6/29/2020 5:33 AM
Server Application Monitor
The application monitor's polling method is set to x86.
  1. Login to the Orion Web Console with SAM admin rights.
  2. Go to the affected application monitor and click Edit Application Monitor.
  3. Override the template and change the polling method from x86 to x64.
  4. Click Submit.
