Access Points doesn't appear in "Top 10 Wireless APs by Clients Count"
In the "Top 10 Wireless APs by Clients Count" view, some Access Points do not appear in the top 10, despite having higher client counts.
1/22/2024 6:01 PM
1/21/2026 4:42 PM
  • In the "Top 10 Wireless APs by Clients Count" view, some Access Points do not appear in the top 10, despite having higher client counts.
  • Upon reviewing the Wireless Access Point table, We observed that the corresponding table entries for those access points are marked as in the 0 available table and Access points marked as 1 are reflected in the top access point client view.
Network Performance Monitor
  • Some APs where the polled status is Up have Available set to 0 in the database.
  • Because the Available column is updated only when status changes, it is not fixed with the next successful poll.
    To address the AP availability issue, perform the following:
    1. Connect to the SolarWinds Platform server.
    2. Open SolarWinds Platform Service Manager from the SolarWinds Platform folder of the start menu.
    3. Stop all SolarWinds Services.
    4. Open Database Manager from the SolarWinds Platform folder of the start menu.
    5. Select Add Orion Server and expand the SQL server in bold.
    6. Right-click the SolarWinds Platform database and select New Query.
    7. Paste the SQL query below and select Execute Query.
    update Wireless_AccessPoints set Available=1 where Status=1 and Available=0
    1. Start all SolarWinds services.
