ASA/Nexus Device Has Gap In VPN Data
ASA or Nexus Devices can have gaps in VPN polling data due to a Bug in the Cisco device which improperly formats the SNMP output of IP address.
1. Review "How VPN monitoring works" within NPM: https://support.solarwinds.com/SuccessCenter/s/article/How-to-monitor-VPN?language=en_US
Cisco ASA and Nexus devices have a Bug which is improperly formatting SNMP data that they are creating.
You can check if you are experiencing this bug by doing an SNMP walk from your device and check if you are getting similar results to below:
(Hex-String has been removed for privacy)
This corruption occurs on OID: 1.3.6.1.4.1.9.9.171.1.3.2.1.5
This OID is suppose to be in Hex format
2. The SolarWinds.Node.ASA.Snmp.log will show the following Error message: "Couldn't resolve valid IP address from HexValue: , DotValue: . Or IP doesn't meet the validation predicates."
Is not in Hex format the JobEngine is unable to convert the Hex into an IP address for doing the VPN analysis.
You will find errors in the Collector service logs (\Programdata\Solarwinds\Collector\Logs\Plugins\SolarWinds.Node.ASA.Snmp.log)
In the SolarWinds.Node>ASA.Snmp log you will find the following error:
SolarWinds.ASA.Common.Helpers.IpAddressResolver - Couldn't convert IP address from value '' using DotIpAddressConverter.
System.ArgumentNullException: Value cannot be null.
Parameter name: value
at SolarWinds.ASA.Common.Helpers.HexIpAddressConverter.Convert(String value)
at SolarWinds.ASA.Common.Helpers.IpAddressResolver.Convert(IIpAddressConverter converter, String value)
Error message with debug enabled:
DEBUG SolarWinds.Orion.Pollers.Framework.SNMP.SnmpManagerAdapter - out-ip: 172.17.98.55 version: 2 queryType: GetBulk timeout: 00:00:02.5000000 error: 0 errStatus:0, errIndex:0 OIDs: 1.3.6.1.4.1.9.9.171.1.5.2.1.1.9.1575767 = OID_TYPE_STRING: b¸Ð (0) [62B8D013]|1.3.6.1.4.1.9.9.171.1.5.2.1.1.9.1575768 = OID_TYPE_STRING: ¦±ºæ (0) [A6B1BAE6]|1.3.6.1.4.1.9.9.171.1.5.2.1.1.9.1575769 = OID_TYPE_STRING: ¦‰°Ö (0) [A689B0D6]|1.3.6.1.4.1.9.9.171.1.5.2.1.1.9.1575770 = OID_TYPE_STRING: ¦±¹û (0) [A6B1B9FB]|1.3.6.1.4.1.9.9.171.1.5.2.1.1.9.1575771 = OID_TYPE_STRING: D
(0) [181C440E]
Alternative Errors:
ERROR SolarWinds.Orion.Collector.Plugins.Pollers.PollerResultPreProcessorBase`1 - N.VPN_SiteToSite_Status.SNMP.CiscoAsa poller result for Node 2304. Info: Failed. Polling Finished: 3/25/2020 3:37:18 AM. Error message: Couldn't resolve valid IP address from HexValue: , DotValue: . Or IP doesn't meet the validation predicates.
- Couldn't resolve valid IP address from HexValue: , DotValue: . Or IP doesn't meet the validation predicates.
- System.ArgumentNullException: Value cannot be null.
If you do have any of these above listed errors Please contact Cisco Technical Support to get assistance with fixing the bug your device has.
