Security Compliance
ARM server will not connect or Collectors will not connect to the ARM server.
In ARM version 2020.2.3 Access Rights Manager started using GRPC. This has caused connection issues with the ARM server itself and the collectors.
Variable name: GRPC_DNS_RSOLVER
Variable value: Native
1. Right-click on the Windows Tab.
2. click system
3. click on system info
4. click on advanced system settings
5. In system Properties, click on Environmental Variables..
6. Under System variables
7. choose new
9.
10. enter Variable name: GRPC_DNS_RESOLVER
Once you have done this on the ARM server do the same on all the collectors.
