Security Compliance
ARM Web Portal is not available - Error 503
This article explains how to mitigate a problem with the ARM Web Portal not opening and showing 'Error 503'.
10/26/2020 12:01 PM
6/8/2021 2:05 PM
The ARM web portal does not load and the following error is displayed:
Access Rights Manager
It may be that the required ARM WebAPI AppPool in IIS has been stopped:
(Screenshots property of © 2020 Microsoft)
Start the relevant AppPool. After that it should work fine.
