API-Only polled nodes are not showing NTA Flow data
This article explains how to resolve an issue where NTA does not display flow data for nodes that are polled using the API-Only polling method, even though NetFlow/IPFIX packets are actively being received by the SolarWinds collector.
After adding or converting a node to API-Only polling, NTA stops displaying flow data for the device. The following symptoms are observed:
NetFlow/IPFIX flow packets are confirmed arriving at the SolarWinds NetFlow Receiver (verified via packet capture or FPS counters).
The interface index values in the incoming flow data match the interface indexes assigned to the API-polled node's interfaces in the
Interfacestable. -
NTA does not associate the received flows with the monitored interfaces.
The Last Received Flows timestamp does not update on the NTA resources for the node.
No traffic data appears on any NTA widget for the affected node.
When a node is polled via the API-Only method, the interfaces are assigned an InterfaceSubType value that differs from SNMP-polled interfaces (which use InterfaceSubType = 0). The NTA NetFlow Service internally builds interface mappings using a query that filters on specific InterfaceSubType values. API-polled interface subtypes are excluded from this filter, which prevents NTA from creating a mapping between the incoming flow data and the monitored interfaces.
Note: This issue affects any device type using API-Only polling, including but not limited to Aruba SD-WAN devices. You need to perform the steps if you added a new node via API-Only polling specially if that node is configured to send Netflow data to Solarwinds Server.
Workaround
| Warning: Before running any SQL script against the SolarWinds Platform database, ensure you have a valid backup. Modifying database tables directly can cause unintended results if not done carefully. SolarWinds recommends testing in a non-production environment first. |
To work around this issue, run the following SQL script against the SolarWinds Platform database to manually reconcile the NetFlowInterfaceSources_Mapping table with the correct InterfaceID:
UPDATE NetFlowInterfaceSources_Mapping
SET EntityID = i.InterfaceID, Managed = 1, Enabled = 1
FROM NetFlowInterfaceSources_Mapping nm
INNER JOIN Interfaces i
ON i.InterfaceIndex = nm.InterfaceIndex AND i.NodeID = nm.NodeId
WHERE nm.EntityType = 'Orion.NPM.Interfaces'
AND nm.EntityID IS NULL
AND nm.LastTimeAsked IS NOT NULL
After executing the script, NTA should begin associating incoming flows with the correct interfaces within the next polling cycle.
| Note: This workaround must be re-executed each time a new API-Only polled node is added that is also configured to export NetFlow/IPFIX traffic data to the SolarWinds collector. |
Fix
A fix is planned for a future NTA release. Watch this article for updates.
