Tools
553 FTP response code
Created by Aileen de Lara_ret, last modified by Aileen de Lara_ret on May 09, 2017 Views: 244 Votes: 0 Revisions: 3
10/25/2018 8:08 PM
10/25/2018 8:08 PM
This article provides information on 553 FTP response code.
A 553 response code may be given in response to any command requiring or supporting the use of a file name as a parameter. It is a permanent negative reply, which means the client is discouraged from sending the command again since the server will respond with the same reply code. It is usually due to the file name contained as a parameter violating the file naming policies existing on the server. Issuing the command again with a different file name may result in a different reply code.
Example response
553 Requested action not taken; File name not allowed.
Possible commands
