Tools
551 FTP response code
A 551 response code may be sent in response to any command requiring the server to store information locally. It is a permanent negative reply, which means the client is discouraged from sending the command again since the server will respond with the same response code.
10/25/2018 8:02 PM
10/25/2018 8:02 PM
This article provides information on 551 FTP response code.
A 551 response code may be sent in response to any command requiring the server to store information locally. It is a permanent negative reply, which means the client is discouraged from sending the command again since the server will respond with the same response code. It is only applicable when the page file structure is being used (through a STRU P command).
Example response
551 Requested action aborted: page type unknown.
Possible commands
