Tools
536 FTP response code
A 536 response code may be sent in response to a PROT command when the requested protection level is unsupported by the current security mechanism. It is a permanent negative response, which means the client is discouraged from sending the command again since the server will respond with the same response code.
11/14/2018 3:17 PM
11/14/2018 3:17 PM
This article provides information on 536 FTP response code.
A 536 response code may be sent in response to a PROT command when the requested protection level is unsupported by the current security mechanism. It is a permanent negative response, which means the client is discouraged from sending the command again since the server will respond with the same response code. Negotiating a different security mechanism using the AUTH command can result in a different response code.
Example response
536 Requested PROT level not supported by mechanism.
Possible command
PROT FTP command
