Tools
532 FTP response code
A 532 response code may be sent in response to any command involving the storage or manipulation of files on the server. It is a permanent negative response, which means the client is discouraged from sending the command again since the server will respond with the same response code. Providing account information first and sending the command again can result in a different response code.
Example response
532 Need account for storing files.
