Tools
503 FTP response code
A 503 response code may be sent in response to any command that requires the successful processing of previous commands first. It is a permanent negative reply, which means the client is discouraged from immediately sending the command again since the server will respond with the same reply code.
10/25/2018 7:35 PM
10/25/2018 7:35 PM
This article provides information on 503 FTP response code.
A 503 response code may be sent in response to any command that requires the successful processing of previous commands first. It is a permanent negative reply, which means the client is discouraged from immediately sending the command again since the server will respond with the same reply code. For example, a file rename requires a successful RNFR command before the RNTO command can be sent. Sending the RNTOcommand first will result in a 503 response code.
Example response
503 Bad sequence of commands.
Possible commands
