Tools
425 FTP response code
This article provides information on 425 FTP response codes.
10/25/2018 6:49 PM
10/25/2018 6:49 PM
A 425 response code may be sent in response to any command requiring the usage of a data connection if the server is unable to open a data connection. This is considered a transient negative reply as a temporary condition. It may indicate that the server does not immediately have the resources to open a data connection. In this case, the client is encouraged to restart the FTP transaction and try again.
Example response
425 Can't open data connection.
Possible commands
Ensure that the Data Ports are open in the Network Firewall rules depending on the required port by Active or Passive FTP.
