Tools
334 FTP response code
A 334 code is sent in response to the AUTH command when the requested security mechanism is accepted and includes a security data to be used by the client to construct the next command. The square brackets are not to be included in the response and it is optional to indicate the security data in the response.
11/14/2018 2:49 PM
11/14/2018 2:49 PM
This article explains why the 334 FTP response code is sent.
Example response
334 [ADAT=base64data]
Possible command
AUTH FTP command
