2502 and 2503 error codes when installing or uninstalling NPM
There is a 2502 or 2503 error code displayed when you install or uninstall NPM: The installer encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2502. The installer encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2503.
10/17/2018 7:17 PM
8/25/2022 1:22 PM
  • The installer encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2502.
  • The installer encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2503.
Network Performance Monitor
Remove EOL
    If you encounter these errors, please open a ticket with support.
    Providing details about the issue can help us resolve it.
    You may also use a third-party tool to uninstall the module.
