Tools
125 FTP response code
This article explains why the 125 FTP response code is sent.
10/24/2018 7:17 PM
10/24/2018 7:17 PM
This article describes why the 125 FTP response code is sent.
The server may use this code in response to a command initiating a file transfer if the data connection is already established. After sending or receiving this response, the server or client may begin sending data over the data connection.
Example response
125 Data connection already opened; transfer starting.
Possible commands
See also
150 FTP response code
