Set Custom 'Listening on' Port for Syslog Messages
Set the Orion polling engine to listen on a specific port for syslog messages. Incoming syslog messages sent to a custom port. Reconfigure the listening on port.
3/28/2020 4:15 AM
3/28/2020 4:47 AM
If your devices do not use the default syslog port to send messages, you must also modify the Orion server to listen to that port. This describes how to set a custom syslog port for the Syslog service to listen on.
See also:
Port Requirements: SAM
Configure secure encrypted syslog settings for Log Analyzer
Orion Platform
  1. Access the Orion polling engine.
  2. Access the installation path.
C:\Program Files (x86)\SolarWinds\Orion\SyslogTraps\SyslogService.exe.config
  1. Launch the config file and add key in the <appSettings> section. Example
<appSettings>
  <add key="UDPListenPort" value="514"/>
</appSettings>
