Database Management
DPA monitor fails to start on SQL AG listener with max allowed monitored database sessions exceeded
This involved SolarWinds DPA monitors failing to start for a SQL Server Availability Group listener because the monitored database session threshold was being exceeded. The reported error indicated max allowed monitored database sessions exceeded: 23 > 20 and referenced checking whether the instance was registered through multiple AG listeners.
The issue was traced to DPA monitored-session limit settings in system.properties. Troubleshooting focused on confirming the correct file location, increasing the relevant session-limit values, and restarting the Ignite / DPA service.
The failure was tied to DPA monitored database session limits rather than a generic monitor startup issue.
Confirm the correct
system.propertiesfile location on the DPA server. -
Review the monitored session limit settings and make sure they are active (not commented out).
Recommended values used during troubleshooting:
com.confio.idc.database.datasource.maxAllowedSessions=25 -
com.confio.idc.database.datasource.maxAllowedSessionsForAg=30
Restart the Ignite / DPA service after updating the values.
